New Ricoh IM C300 Error code SC670-002
  • Suppotech
    • Jun 2023
    • 11
    [Error Code] New Ricoh IM C300 Error code SC670-002
    Hi Friends.
    I have a new machine Ricoh IM C300 with error SC 670-002
    Can you help me...
    • 8202
    Re: New Ricoh IM C300 Error code SC670-002
    Originally posted by Suppotech
    Hi Friends.
    Can you help me...
    Sometimes a faulty toner bottle chip can cause SC670-xx
    Try shutting down the device then turn back on with all toners removed then install them one by one.
      • 37590
      Hi Friends.
      Can you help me...
      • sandmanmac
        • 3990
        Hi Friends.
        Can you help me...
        New = Warranty
        Contact the dealer/ seller.
        Oh wait!
        Let me guess, you didn't purchase it through a 'usual process', so you're likely up the creek.....
        • Suppotech
          • Jun 2023
          • 11
          i am the seller...
          Originally posted by sandmanmac
          New = Warranty
          Oh wait!
          • score23
            • Jun 2010
            • 12
            same issue but with ours it only happens through the DF or scanning from the glass. Printing is fine, updated f/W, changed out power supply. no change, im at a loss on what it is
              • 8202
              Each time we see the SC670 error it has been caused by a corrupt or soiled toner bottle chip.
              Here's a service manual update / bulletin on this error.
              SC672-02.pdf
