ricoh mpc 4504 does not have the scanning option
  • billm
    • Jun 2012
    • 50
    we got this used it does not have the scanning option or the interface option it also has a meter of 8 I think that the NVM was changed by someone else how do I get the options back, there is nothing in the SD card slots
  • GIUBOSS
    • 1437
    Re: ricoh mpc 4504 does not have the scanning option
    Check this: 5985 [Device Setting]5-985-00
    1
    On Board NIC
    • billm
      • Jun 2012
      • 50
      Thanks that did the trick
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        It most likely had a Fiery print controller attached to it in its prior life.
          • 37556
          Even with a Fiery attached you normally do not disable the On Board NIC. It is still needed for WIM and a number of other network related functions.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
              • 37556
              As i recall the installation instructions used to include instructions as to how to enable GW scanning if the customer was not pleased with scanning through the Fiery.
