Re: SC 672
hi, look, I don't recommend contact spray, because they would mix with the dirt on the card, and usually some leave an oily film that oxidizes over time.
"washing" with alcohol and a brush is the best solution, moreover it dries quickly.
excellent solution is to wash with water and degreasing detergent, and a brush (as someone suggested), but it takes longer to dry, and much more compressed air.
I want to underline that this home remedy, it's not the definitive solution to sc, but I've verified that it often works, let's say 3 out of 10(?)... the internal environment of a copier machine, is not the ideal habitat for an electronic so sophisticated, as you well know, there is an exchange of air from the fans which transports: dust, toner, grease, smog, heat, etc...all this is deposited on the card, and oxidizes with the oxygen on the electronics, creating unexpected malfunctions.
