IMC 4500 Fusing issues
  • Exodia-P4
    • Jan 2023
    • 134
    Hello everybody
    I have the same problem on 4 or 5 new IMC 4500. There are reports on the prints (as if the fuse dont heating enough).
    We have already update all copiers, change fusing unit with a new, increase fusing temperature... always the same problem !
    We have called too the Hotline but no solution for now... other similar cases are know today.
    Have you an idea how I can resolve this problem ?
    Thanks you
  • davidmtupper
    • Jul 2021
    • 326
    Re: IMC 4500 Fusing issues
    Is it all for the same customer? If so try their paper in a different copier/printer. It's very unusual to have an issue like this on 4-5 of those, we have dozens (maybe more if you include all the IM series) in the field and very few fuser issues.
      Originally posted by Exodia-P4
      Hello everybody
      Thanks you
      a few Q's for you:
      what weight media are they printing on?
      does it match what the tray is defined for?
      what type paper?
      plain.. glossy..letterhead.. heavy .. cardstock?
      is that setting right for the tray?
      OEM toner?
      OEM Drum/Dev?
      total page count?
      any service parts over life?
      send PDF's scans of issues
        • 37484
        Hello everybody
        Thanks you
        As if not more often than not, fusing offset b=can be caused by the fusing temperature being to high. If it only happens when printing and not when copying, faxing or internal reports the IM C4500 is not properly configured to use the setting from the PC. Either that or the paper set for the document is not the same as what is in the paper tray. Photo glossy paper can be a major pain to adjust a machine for.
        • Exodia-P4
          • Jan 2023
          • 134
          No it's not the same customer...
          • Exodia-P4
            • Jan 2023
            • 134
            a few Q's for you:
            what type paper?
            OEM toner?
            OEM Drum/Dev?
            total page count?
            what weight media are they printing on? 80g
            does it match what the tray is defined for? Yes
            what type paper? normal
            is that setting right for the tray? yes
            OEM toner? yes
            OEM Drum/Dev? yes
            total page count? less of 20k for each +/-
            send PDF's scans of issues I will try to find them ;)
            • semi
              • Sep 2008
              • 193
              OEM toner? yes
              OEM Drum/Dev? yes
              Change STR- SP5191-001 Update device to latest package
              • Exodia-P4
                • Jan 2023
                • 134
                I test on a copier that I have and SP5191 is already at "1".... What does this bit change ?
                • GIUBOSS
                  • 1435
                  5191
                  [Mode Set]
                  Shifts to the power save mode or not.
                  001 Power Str Set *CTL
                  [0 or 1 / 1 / 1/step]
                  0: OFF, 1: ON
                  • Exodia-P4
                    • Jan 2023
                    • 134
                    Originally posted by GIUBOSS
                    5191
                    [Mode Set]
                    0: OFF, 1: ON
                    Ok I will try it but the problem come when the copier is start and not after standby...
                    • tjvincent
                      • 280
                      We have literally hundreds of this model in the field and have not had that issue. These machines are bullet proof
                      • GIUBOSS
                        • 1435
                        I just answered your question I didn't say it's the solution
                        • GIUBOSS
                          • 1435
                          Apparently it would seem like a series of faulty machines from a common problem, if they are under warranty then you should insist on calling the hotline. Do you have at least one of this model that works well?
                          • Exodia-P4
                            • Jan 2023
                            • 134
                            Yes we have 2 or 3 witch are ok...
                            • GIUBOSS
                              • 1435
                              If somehow you can play the game of exchanging parts and electronic boards to find the problem of the defective ones
