Ricoh MP501 Not able to set up on Network
  • laser801
    • May 2014
    • 151
    Hello all.. I've been asked for help by our I.T. Person on a MP501... He tried to set up 2 of these...One was successful that had RXSPSERVLET on board and the other was unsuccessful which had ARGOS on board... I personally don't know anything about this, but it would be helpful with any info for our I.T. guy... Thanks, Laser801
  • dalewb74
    • Feb 2018
    • 1153
    Re: Ricoh MP501 Not able to set up on Network
    ummmm call ricoh???
      • 37488
      Did your IT person properly configured HTTPS on the MP 501 before installing ARGOS Onboard? Just be aware that once a Device Certificate is created you will have to access WIM as an HTTPS:// device or you will get a connection error.
      Security check
      • laser801
        • May 2014
        • 151
        Security check
        I will check with him... Thanks much !
