please wait on aficio 2027
  • djq2
    • Jun 2008
    • 25
    Hi.All. having a problem on an aficio 2027, machine run's up and please
    wait message stay's on screen.. disconnected the df.. interchange unit..
    duplex units.. still please wait..!!! have tried software reboot.. The machine is a four hour drive away... so any help would be much appricated.
  • Ltd
    • 90
    Disconnect Hard drive to see if it is ready or not . Mostly hard drive failure.
    • djq2
      • Jun 2008
      • 25
      Thank's for reply LTD... there is no hard drive fitted to this machine..
      • Caveman
        • 82
        Had a similar problem - needed to replace the print controller (located behind where the hard drive would be located).
        Caveman
        • djq2
          • Jun 2008
          • 25
          Hi. Caveman. would that be t pba that the nvram is located on.????
          • jummamaster
            • Mar 2009
            • 99
            check the fusing lamps and other fusing unit parts. I had a similar problem, solved by replacing the fixing lamp.
            Ricoh Error Codes
            Canon Error 5100
            Canon Error B200
            j
            c
            • Ltd
              • 90
              If machinne have NIC , disconnect it.
              • stephend
                Senior Technician
                • 306
                Please wait
                If you have on hand a controller (that one with the NVRAM on it) replace it.
                • antongreen
                  PLEASE WAIT
                  Try changing the dislay not sure what bit of the display it is yet but the display will fix it
                  • digicor
                    • 1152
                    try replacing the print controller, or re do the developer, ive had a ricoh do this when the whole time it was trying to bring the dev up to speed aND the dv was bad or something, but changing it solved the issue. is it cycling like it trying to tone up?or is it just sitting there not doing anything?
                    • techshare
                      • Mar 2009
                      • 15
                      I agree with Jummamaster. Check hot roller bearing ring, be sure it in place.
                      • djq2
                        • Jun 2008
                        • 25
                        2027 aficio please wait
                        Hi. All just a post to say thank's to you all for your imput in to the recent problem i was having with a please wait message on the display of an 2027
                        aficio... The problem was rectifed when i replaced the NVRAM on the controller pba....
