Ricoh AF2060 SC555
  • Drews01
    Ricoh AF2060 SC555
    I got a Ricoh AF2060 thats throwing a SC555. I know what it stands for. But the thermo stat is failing..?
    Any body with a clue? Ricoh tells me to wrap the thermister wires with electrcal tape..? What ever....
  • Herrmann
    • Jan 2006
    • 792
    thermostat failing? did you mean, that the thermoswitches are triggering continously?
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • Drews01
      Yes, the thermoswitches are triggering continously.
      • bonnie750
        • 302
        have you replaced the thermostats with the latest parts?
        • Herrmann
          • Jan 2006
          • 792
          check the triac on the ac board, it can be short circuited.
          • Jomama46
            • 2900
            Often the fuser wires will have open insulation causing shorts.
            But the first thing is to put the new thermostat in.
            sigpic
            A+; Network +; PDI+
            • Jomama46
              • 2900
              Also you can monitor the fuser temp in SP mode.
              sigpic
              A+; Network +; PDI+
              • Herrmann
                • Jan 2006
                • 792
                Hmm... in that case the RCD should trigger
                • Jomama46
                  • 2900
                  RCD?
                  sigpic
                  A+; Network +; PDI+
                  • Herrmann
                    • Jan 2006
                    • 792
                    in german we call it "Fehlerstromschutzschalter", a device, which triggers, if not the same amount of current which flows to the device/circuit, returns. That would indicate, that some current flows the wrong way, maybe someone, who touch the line, per example; or neutral shorts against earth
                    "residual current device" should be the right translation, i hope
                    • Drews01
                      Fixed!! New Thermistors, and thermoswitches.
                      Thanks for the help...
                      Drew
                      • Shadow1
                        • Sep 2008
                        • 1642
                        Here in the US we call it a Ground Fault Circuit Interrupter or GFCI - they're only required by code (in most states) if the outlet is within 6 feet (2 Meters) of a water source, or in a Kitchen of Bathroom.
                        Just FYI, I have also seen this problem where the leads from the fusing lamps have frayed and shorted to ground - took me a while to find what happened because the short was intermittent and would sometimes go away if you bumped the fuser assembly just right (like pulling it out to put new thermostats in)
                        73 DE W5SSJ
