Ricoh mp 7502 please help
  • Ismael shof
    • Jul 2023
    • 5
    When the machine does not work for a certain period of time, the machine automatically enters “Power saving mode.” I have a problem, after 4 to 5 minutes, that the heater and the cooling fan are working without lighting the
    machine screen
    Is
    there a program to solve this problem??
    * Update the machine to a new version
    * It is timed after 15 time settings Please Help The
    customer hated the machine because of this problem ������
  • Ismael shof
    • Jul 2023
    • 5
    Re: Ricoh mp 7502 please help
    • luca72
      • Oct 2017
      • 1766
      machine screen
      Is
      I suggest to you, of check this problem, of Person, dont listen the customer, the martini series usualy run some fan for long time, also in stand by....at most, blow all the filters with air (see sm assistant)...next step its a possibility to change the activation time in some sp in 1-1xx (usualy)..i dont R..emember esactly... i should look on sm, but in my opinion, it's normal, at least. ...I've also had a couple of tickets opened for this thing in the past
      "I'll be back"
      • Ismael shof
        • Jul 2023
        • 5
        Thank you for your suggestion.
        I checked the machine myself that it is really very annoying
        • Codex
          • May 2008
          • 701
          You can disable the "screen standby" time in user mode... Set it to always on or choose a time... 10...15minutes..
          Inviato dal mio SM-S901B utilizzando Tapatalk
          Memento Audere Semper
            • 37449
            One thing I have encountered in the past is that some machines do not recover properly if multiple time out are set to the same delay, common with default settings. I would set every thing to a 10 to 15 second in time out times. Normally I would set them to sequence in the following order:
            1. User time out
            2. Function time out
            3. Screen standby
            4. Energy saver
            5. Sleep mode
            One other thing, for models with a walk-up sensor, disable it. Normal foot traffic within an office can keep triggering it.
            • Ismael shof
              • Jul 2023
              • 5
              Thanks for the help.
              Tomorrow I'll work on the machine.
              • MIKON
                • Jul 2015
                • 186
                The controller box cooling fan runs countinously .Part # is AX640177
                • luca72
                  • Oct 2017
                  • 1766
                  did you figure out which fan it is exactly?
                  "I'll be back"
                    • 37449
                    Yea the u=is the part number for the fan on top of the controller box and yes it does run constantly. The fan's shaft bushing could be running dry and when they do they make a lot of noise until the seize at which point they become silent and the boards in the controller box roast.
                    • luca72
                      • Oct 2017
                      • 1766
                      you're right slimslob, the controller fan, always runs, but, at this point, maybe, I didn't understand this discussion well(?).....in the end all this mess for a noisy controller fan?
                      "I'll be back"
                      • Ismael shof
                        • Jul 2023
                        • 5
                        Good evening my friends
                        Not from the fan from the control box
                        I'm still working on solving the problem
                        A new firmware for the machine was downloaded from the Ricoh website, and unfortunately nothing happened
                        Now I am working on taking a copy of the software from a machine that works perfectly I will give it a try, and thanks to all, I will let you know the results.
                        • Codex
                          • May 2008
                          • 701
                          Sorry, i'm not shure if i understood the problem is it:
                          1. A noisy fan?
                          2. the machine goes to stand by during work (machine works, but screen turns off)
                          3 The machine stopps working and goes in stand by mode
                          4. The fans works for a period of time after the machine stopps working ( there are SP settings for that)
                          • luca72
                            • Oct 2017
                            • 1766
                            if I understand correctly, you mean to make a dump of firmware from a working unit?....if you succeed, you absolutely must let us know how you did it.
                            "I'll be back"
                            • DRichard
                              • May 2008
                              • 482
                              That's what I understood him to say also...AND I, too would like to know how to do it. About twenty or twenty-five years ago Ricoh allowed you to do this through their service mode. However, I have not seen a setting that enabled it for a very long time.
                              "Enjoy every sandwich."
                              -- Warren Zevon
