Ricoh Pro C7210sx operation panel
  • mita
    • Sep 2010
    • 87
    My operation panel touch screen not responding. Tried reboot several times no luck and checked connections.
  • kevslane
    • Mar 2017
    • 24
    Re: Ricoh Pro C7210sx operation panel
    Have you tried loading the SOP firmware onto the screen?
    Sent from my SM-A526B using Tapatalk
    • mita
      • Sep 2010
      • 87
      no not yet will this today
      • GIUBOSS
        • 1385
        Have you tried disconnecting from the network? Or shut it down using the special shutdown procedure used for maintenance?
          • 37357
          I have had exactly 1 touch screen problem with a SOP. That is exactly how I cleared it.
          • RG1964
            • Jul 2009
            • 56
            Is the screen not working or the touch part?
            The touch part is the USB connector at the back of the screen.
            Get's disconnected if they rotate the screen much.
