Ricoh Aficio 700 Doesn't stop adding toner.
This unit is torturing me. It does not stop adding toner and the add toner light will not go away. It keeps adding and adding toner without need.
We have replaced the toner density sensor (AW230019), toner end sensor, as well as the toner supply clutch (AX200093) and this did not fix the problem. Could this be a main board issue?
Please help; thank you.
