Problem Ricoh PRO C 651 EX sc 402. Help Fix it.
  • FastCopy
    • Sep 2023
    • 4
    [Error Code] Problem Ricoh PRO C 651 EX sc 402. Help Fix it.
    Hello , I Have 9 Ricoh Pro C 651Ex
    This last one i bought a almost brand new Ricoh Pro C 651Ex
    but i have a problem it shows me an error code sc 402 code.
    i think its not pumping toner in the toner pump.
    I tried changing drum unit , i tried chaned toner pump , i changed the transfer unit , tried chaning ld unit
    nothing still the same.
    i put new toner , put new drum unit .
    still the same.
    i put the same unit and same toner pump in other machine it works.
    i try to do sp 3011 - manually process
    it failes
    i try developer mix , it fails.
    Can you please help.
  • GIUBOSS
    • 1386
    Re: Problem Ricoh PRO C 651 EX sc 402. Help Fix it.
    still the same.
    it failes
    You have a problem in developer unit M , check it, it probably didn't initialize it correctly
    • FastCopy
      • Sep 2023
      • 4
      How do u mean i didnt initialize it correctly can you be morre specificy , because i did , i put the same unit in other printer it works. thats the problem
      the guy who sold it to me before selling did a whole reset on the printer.
        • 37365
        still the same.
        it failes
        From the service manual:
        • Dust shield glass is dirty
        • ITB unit transfer power pack defective
        • LD unit inside laser unit defective
        If SP3012 returned a process control error code:
        • Code 55, 59. Replace developer.
        • Code 56. Clean the toner shield glass, or replace transfer power pack.
        • Code 61. Replace laser unit
        My guess is the toner shield glass is dirty.
        • FastCopy
          • Sep 2023
          • 4
          i did clean toner shield glass but still the same problem.
          i tried everything i know i did process control it fails , i did developer mix it fails , nothing helps.
          • mikadonovan
            • May 2008
            • 2931
            If he did a memory clear, you will need to find the birth certificate for the machine and reinput the original values manually.
            NEVER ASSUME ANYTHING
