Not printing Ricoh C305
  • RicohBoomer
    • May 2022
    • 40
    #16
    Re: Not printing Ricoh C305
    Originally posted by Jinn
    By connecting the machine with laptop directly and assigning the IPs manually as per access control range finally it started Printing. Webpage is also accessible now. But I don't know the Admin Password so that this access control security could turn off.
    It's not taking default passwords. Admin/admin.
    Admin password can be seen in SMC report? Or factory reset is required? If Yes then what is the procedure?
    I will PM you what is typically the standard.
    • DRichard
      • May 2008
      • 482
      #17
      Originally posted by RicohBoomer
      Access control is a bit annoying if you somehow find yourself outside of it. Easiest method is to take a laptop and directly connect yourself to the ethernet port of the printer, and put both you and the printer within the access limited range.
      Then you can access the webpage and from there deactivate access control. Located in Configuration > Security.
      As far as I can remember there is no way to deactivate access control from the panel unless you factory reset the machine.
      We have a customer who does this very thing with their fleet. We have recently upgraded their machines and are re-purposing the old machines. I am having to open up the IP address ranges with each of them. It was very aggravating early on.
      "Enjoy every sandwich."
      -- Warren Zevon
        • 37357
        #18
        In access control range there are IPs entered. I think that is the actual reason its not printing. From where this option can turn off?
        You can try SP 5801-011, clear Network Control Services. You will have to set all the interface information afterwards.
