The Much Maligned MP4000/5000
  • edwin3268
    • Sep 2009
    • 22
    #46
    You guys....geez. Be greatful that the design is NOT like the web assemblies for Panasonic DP-80xx or C-213's. At least you dont have the cheap little solenoid and actuator arm on the front side to deal with upon changing web and roller.
    • Shadow1
      • Sep 2008
      • 1642
      #47
      Have you changed a web on one of these???
      I don't work on Panasonic, but I can't imagine they are much worse.
      I put the snakeskin oil roller in all my machines like df3036 posted back at the beginning of this thread - works great, takes 2 minutes to change
      73 DE W5SSJ
      • Koosie
        • Nov 2008
        • 121
        #48
        I have removed the web unit from a machine and it worked great! I'm testing to see for any long term effects.
        • Jomama46
          • 2900
          #49
          You are running without the web?
          sigpic
          A+; Network +; PDI+
          • Koosie
            • Nov 2008
            • 121
            #50
            Yes, but they've only done about 20,000 without a problem. Will see if the hot roller does its life. I think the pressure roller cleaner on the pressure roller like in the prev. models is enough.
            • Jomama46
              • 2900
              #51
              Interesting. Please keep us updated.
              sigpic
              A+; Network +; PDI+
              • E Winter
                #52
                +1
                All I can say is that the fusing unit usually runs "2 + X" pm cycles (>320k). If I have to choose to keep the web installed OR need to rebuilt the fuser at every PM cycle, I'd prefer to keep the web.
                • Shadow1
                  • Sep 2008
                  • 1642
                  #53
                  Using the SnakeSkin roller gets me about the same results as with the web as far as life. The exception is the cleaning roller actually gets dirty again - with the web they were almost completely clean when the hot roller finally failed, without it they build up as bad as in the old series machines. Not a problem, though - just normal buildup.
                  I'd be interested to see how the life is running dry, too.
                  73 DE W5SSJ
                  • Koosie
                    • Nov 2008
                    • 121
                    #54
                    I will post results asap.
                    • DH1980
                      • Mar 2009
                      • 52
                      #55
                      When will they replace the MP 4000?
                      • Shadow1
                        • Sep 2008
                        • 1642
                        #56
                        Got an announcement yesterday - MP4001 Release Jan 15. No info on updated toner or same old crap.
                        73 DE W5SSJ
                        • ucinn
                          • Jun 2009
                          • 383
                          #57
                          ldo50 and ld345's
                          what we have done to fix this problem with the toner/mag roller was to degrade the machine to a ld245. We swap out the toner motor and developer, use the b0799640 developer and flag the machine so when the customer orders toner, they get the ld245 toner. Quality problems gone.
                          • Shadow1
                            • Sep 2008
                            • 1642
                            #58
                            That works great as long as you have enough control over supplies to make it happen - Us Ricoh Direct guys can't swing that.
                            73 DE W5SSJ
                            • zyqwiz
                              • Jun 2009
                              • 333
                              #59
                              The new ones are the same as the CSP versions of the old ones!
                              • DH1980
                                • Mar 2009
                                • 52
                                #60
                                Do you do this to all MP 4000's. When setting up new machines you change the toner motor, are there any settings you change, does it last
                                160k? Any side effects?
