Windows server 2022 & mpc2051 - smb v2 dont work, and smb v1 instead work
  • luca72
    • Oct 2017
    • 1782
    #31
    Re: Windows server 2022 & mpc2051 - smb v2 dont work, and smb v1 instead work
    Originally posted by emiliorsg
    In octopus the last firmware update is 7-2021.
    [ATTACH=CONFIG]59935[/ATTACH]
    thanks, tomorrow morning i re-check the all version module of machine by remote
    "I'll be back"
    • luca72
      • Oct 2017
      • 1782
      #32
      thanks, i think that this sp its same thing of wim settings, but i check this anyway
      "I'll be back"
      • Bourriks
        • May 2016
        • 38
        #33
        this problem is very interesting, but the main thing is allowing an old copier to speak SMB with a recent Windows Server.
        Have you considered using a FTP server on the WS2022 ?
        This would solve your problem with ease.
        • luca72
          • Oct 2017
          • 1782
          #34
          we don't like using ftp, and probably neither does the customer, he's been using scan to folder for years, however we will solve the problem as soon as possible....the defeat is not contemplated..lol
          "I'll be back"
          • Bourriks
            • May 2016
            • 38
            #35
            Some news for this issue ?
            • luca72
              • Oct 2017
              • 1782
              #36
              as terminator said...."I'll be back"
              "I'll be back"
                • 37517
                #37
                If you can not get SMB2 to work scan to folder to work would they be interested in scan to memory device? The USB2.0/SD Slot Type G (D556) may not still be available but you don't really need it. Just make the SP settings shown in the service manual for it and put your thumb drive in the USB slot that the USB2.0/SD Slot Type G (D556) uses. To bring the connection to the front panel just use a USB extension cable. An adapter can be used for SD cards.
                • luca72
                  • Oct 2017
                  • 1782
                  #38
                  thanks, I still have to go, because we are waiting for the data to be transferred from the old server, which we have to retire it, I think this week, for now my IT colleagues have seen the matter, however I am confident, when I go to see I'll find the problem myself.
                  we have to make smbv2 work, no usb or anything else, rather we change the machine
                  "I'll be back"
                  • luca72
                    • Oct 2017
                    • 1782
                    #39
                    [SOLVED] Hi, the replacement of the management software from that customer was taking a long time, but today I went for the noisy fuser, and I took the opportunity to fix it, well...
                    I overwrote the firmware, and disabled and re-enabled smbV2/V3 flag from WIM, and now everything works.
                    I didn't quite understand what resolved the two, I think the second one...ciaooooo
                    "I'll be back"
