Windows server 2022 & mpc2051 - smb v2 dont work, and smb v1 instead work
  • rthonpm
    replied
    Re: Windows server 2022 & mpc2051 - smb v2 dont work, and smb v1 instead work
    In the Web interface, what's the SMB setting under Network > SMB > Advanced Settings? That will allow you to change the dialect that the device uses by enabling or disabling the newer SMB 2 and 3 stack. Just updating the firmware will not enable the feature.
    Server 2008 is a poor reference point as SMB1 couldn't be disabled on its network stack at all, a feature that didn't arrive until Windows 8/Server 2012.
    Sent from my Pixel 6 Pro using Tapatalk
  • luca72
    replied
    Originally posted by Gift
    If it's not a firewall issue, perhaps M$ implemented some sort of SMB patch causing issues even if the device appeared to be SMBv2 ready.
    I barely recall that with an older Ricoh I had to change some settings via telnet to get SMB up and running.
    I think one setting was port related and the other was something with "auth" (entification).
    .....found this:
    smb client auth 1 - this sets ntlm auth level
    smb client port 445 - this changes smb port to 445
    I also had the same feeling, among other things for some time now, it is possible to change the Auth, even from wim, in the interface settings, in fact, yesterday we heard from Ricoh, and the technician told us "it could be that 2022 wants the auth at 2, try checking"
    but you reminded me that my colleague on the phone when I told him to search on the 2051 for "smb port and version settings" in "interface settings" he didn't find it(?)...but do you know what it's like?.. If you don't see it in person, you will never be 100% sure.
  • luca72
    replied
    I've done the wireshark capture before for SMB. It's very informative. It appears to be an SMB problem because it works with SMB1 enabled...which is a bad idea, IMO. If I had to bet, I'd say the copier isn't SMB2 capable...for whatever reason.
    unfortunately I don't know how to use wireshark, I tried some time ago, but it took a long time to understand how it works and interpret the outputs correctly
  • luca72
    replied
    Originally posted by dalewb74
    you said fw has been updated. did you run the package all? if so, then you might look to see if there is one specific for scanning?
    the machine has all the latest firmware modules, in particular "network scanner 10.64" which is the very latest, we check this by remote
  • luca72
    replied
    What version was the old server?
    Has your IT friend tried using wireshark or another utility to capture a session using SMBv2?
    Has anyone checked the network log on the C2051 immediately after a failed scan attempt to see what was recorded as the SMB error?
    the old server, which is still connected in parallel, until the management software is fixed on the new one is a windows server 2008, which I was told worked via smb v1.
    the system registry, which is the first thing I checked on the phone (as I often suggest here on the forum) says "unable to connect" which seems like a connection problem, I remember that I didn't go in person, but only by phone to now, next week a colleague of mine and I should go to disconnect the old server, the colleague hasn't tried with wireshark.
    yesterday we connected remotely, and using power shell with appropriate commands we verified that port 445 is open, and it is.
    we heard from Ricoh, and he suggested that we check that "Auth" is present with a value of 2, if it isn't there, it can't work, at that point not having a 2051 mounted here, I tried to check on one mp171spf, and there is Auth 2, so if the 171 which is from 2007 has it, necessarily the mpc2051 which is from 2009 also has it, this is one of the things I have to try.
  • Gift
    replied
    .....found this:
    replied
  • dalewb74
    replied
    replied
    Originally posted by luca72
    smb 1, it's right for the moment, next week we're going to uninstall the old server, and I'll try to fix the problem, I'm creating a mental "work-flow", on what actions to take to make this blessed smb 2 work
  • luca72
    replied
    Originally posted by UNICORNico
    I think SMB 1.0 on a Server is not the right decision. On a private/office computer that does not contain sensitive data, it is not a bad option at all. But on a Server (I tremble just imagining it) I prefer to ask the opinion of the company's IT technician, and manage with him, access via an FTP link protected by the Firewall, with a local user account with a very secure password.
    Alternatively, they can use direct scanning to the HDD and access through the device's WEB, or add an email account and scan the users' emails.
  • UNICORNico
    replied
    Hi, we have this problem on a new windows 2022 server with scan to folder
    the mpc 2051 (fw updated) doesn't work using smb v2 but we had to activate smb v1, I'll start by saying that I don't follow the server part, but only the machine, the mpc2051 has active smb v2 and port 445, in the wim system registry, the machine with smb v2 says "unable to connect"
    do you have a ideas?
  • luca72
    replied
    Originally posted by General Copiers
    From where are you updating the firmware?
    Since some months I have been updating all the machines using the Firmware Update Tool.
    Some firmware downloaded from the Ricoh portal (I think we use the same one) are not really up to date.
    In this way I was able to use scan to folder from MPC2051 to some Windows 10 and Windows 11 pc (I haven't had to do this on Server 2022 yet but I think it's the same...).
    hi, I also noticed this thing you say, however the latest firmware available for mpc2051 are from 2018, and I remember having updated them I think max a year ago with an SD card, however as they were not present at the time of installation of the server, I had my colleague download RFUT on the phone and run it.
    network support is 10.64
  • rthonpm
    replied
    Server 2022 is the server equivalent of Windows 10 21H2.
  • General Copiers
    replied
  • emiliorsg
    replied
    You have an old copier for such a modern Windows. Any other protocol that Windows uses, 2051 does not have it.
