Ricoh MPC3004, weird noise color print not good
  • UNICORNico
    • May 2018
    • 308
    Re: Ricoh MPC3004, weird noise color print not good
    Originally posted by GeorgeBest
    Customer called for bad imaged color prints. (see picture)
    Checked the Dv units, Cyan and Magenta, seems allright.
    When I enter for a "forced toner supple" in SP modus it gives a noise, high sound, loud.
    Never had a problem like this on a C3004 . .
    tonerhoppers not good?
    making a black copy, its allright
    making a color copy, the noise again. .
    someone a clue here
    Thanks in adcance[ATTACH=CONFIG]59938[/ATTACH]
    In my opinion, I think the problem is in the development units.
    The noise could be caused by their hardening, losing component by the caps/busing and I wouldn't seem strange, that the pine nuts are damaged.
    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
    • luca72
      • Oct 2017
      • 1778
      Originally posted by MIGUELMARCHENA
      [ATTACH=CONFIG]60025[/ATTACH]
      It has happened to me that the internal bushings that go before the sprockets of the developing unit that I sent in the photo with a red circle, are already worn out, they let the developer escape and when they are like that, they generate noise because the sprockets no longer lock together. Well, one turn if another doesn't and there is the noise.
      I don't know if they sell the bushings but yes you should cha TTnge, if not, you should change the development unit, I think
      you made me remember something that I always forget to check, for some time now I have had a strong suspicion that those bushings are the same as those of the martini series (at least one of the two) given that the metis ones are not there as spare parts, it would be a great if they were interchangeable, I have a few leaky units lying around, and I have the martini bushings in stock
      "I'll be back"
