basic setting for extended devices is missing. Ricoh MP C307
  • Marwan
    • Oct 2023
    • 21
    greetings for all,
    basic setting for extended devices is missing , from sitting,i restore the sitting to default ,also i tried to active administrator authentication management also no hope.
    and when i try (ic card/bluetooth software settings) it gives unfortunately sitting2 has stopped
    any suggestion please?
    best regards,
  • Brianneoe
    • May 2015
    • 318
    Re: basic setting for extended devices is missing. Ricoh MP C307
    Update the firmware package and then the App package.
    • anothertech
      • 1759
      Is java disabled in service mode? Check SP5730-1 set to 1 to turn on.
      • lukasha
        • Mar 2025
        • 33
        Hi,
        Did you manage to solve the problem with stopping settings2? Unfortunately I have the same problem, I did the downgrade and update of the software, unfortunately it did not help.
        Lukasha
        • lukasha
          • Mar 2025
          • 33
          For the future - here is the solution to the problem:
          https://www.copytechnet.com/forum/technical-forums/copier-technical-discussion/ricoh-savin-gestetner-lanier/1602005-mp-7503-card-reader-problem?p=1612208#post1612208
          Lukasha
