C901 image problem
  • Discount Printing Service
    • Mar 2009
    • 36
    C901 image problem
    Looking for suggestions on this issue. Top sheet is #100 Classic Linen Cover 270 GSM and the bottom is #100 Cougar Cover 270 GSM. Both printed on Ricoh C901s with exact same custom paper settings. I even tried adjusting the paper transfer current and the image transfer current as well as slow the processing speed from normal to low. 400k and 800k PM done recently.IMG_20231020_000239144~2.jpg
    Thanks,
    John M
    DPS
    Senior Field Technician
    • 37529
    Re: C901 image problem
    The problem might be the texture of the Classic Linen paper. You can see the woven pattern.
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      Originally posted by Discount Printing Service
      Looking for suggestions on this issue. Top sheet is #100 Classic Linen Cover 270 GSM and the bottom is #100 Cougar Cover 270 GSM. Both printed on Ricoh C901s with exact same custom paper settings. I even tried adjusting the paper transfer current and the image transfer current as well as slow the processing speed from normal to low. 400k and 800k PM done recently.[ATTACH=CONFIG]60223[/ATTACH]
      might be machine limitation with that type of media.
      fix the customer first then fix the machine... its simple and makes life more easy.
      • UNICORNico
        • May 2018
        • 308
        The type of paper is usually the great thing forgotten by the client when working with it.
        I know few clients (except very veteran copyists) who know how to pamper/take care of the details with thicknesses and texturing.
        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
