Ricoh Aficio MP2852, Data Clear for lease return
  • Thayer
    • Dec 2017
    • 108
    Hello
    I need to do a data clear for lease return, so it needs to be operating.
    I have formatted HDD, but SMTP setting and customers IP address are still there.
    I found service mode 5801 memory clear, will this clear everything and still be operational??
    I'm not a Ricoh tech!
    Thanks in advance
    Thayer
    • 37553
    Re: Ricoh Aficio MP2852, Data Clear for lease return
    SP 5801-010 and -011 should clear all the network settings. Never do -001 or -002. If you do you will be spending hours trying to manually adjust line position in order to get it close enough for the automatic adjustment to work.
    • sandmanmac
      • 3983
      Respectfully Tim, this is an old B&W beast, and I don't fret too much about doing a clear all on any B&W units when I want to wipe everything - especially if it's just going back to a leasing company.
      • copier tech
        • 8188
        Originally posted by Thayer
        Hello
        Thanks in advance
        Thayer
        Yes just run SP-5801 ALL clear this device won't have any issues after this, we do this on all devices, even colour.
        Or since you have formatted the HDD this will have delete the address book. You manually delete the SMTP settings, just leave the fields blank.
        • Thayer
          • Dec 2017
          • 108
          Thanks for the help!
          Machines are ready for the truck.
