ricoh pro 5100 paper cooling roller settings error
  • benzkung777
    • Nov 2023
    • 1
    370279436_2718702458267409_1784015086796169801_n.jpg370261584_1099731654533945_934243323071940933_n.jpg
    • 37641
    Re: ricoh pro 5100 paper cooling roller settings error
    What were you doing prior to the error?
    • anothertech
      • 1771
      Did you service the fuser and not put the cooling roller back in, or did you swap out the fuser and leave the cooling roller in the old fuser?
        • 37641
        Or put it in but didn't properly tighten the screws
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          OR better still put the shoulder screws in the wrong place.
          • mfrigault
            • Feb 2017
            • 18
            Make sure the PUSH SWITCH COVER is still on the back of the paper cooling roller assy. If not, you can order D1357084.
