MP 501 Paper tray 2 dont lift paper
  • Codex
    • May 2008
    • 704
    Hello guys
    I have the same problem with two MP 501 on different customers
    It seems like the paper tray 2 didnt activate properly the paper type sensor on the right side , and remains down.if i touch the tray or push a little bit the tray lift motor starts to work and it recognizes the correct format.
    If i close the tray it remains a bigger gap on the sides than Tray 1, but there is no regulation screw or similar .
    Its the second machine with exact the same issue. Is this a known issue with this machines?, have someone the same problem??.
    Thank You !
    Memento Audere Semper
  • luca72
    • Oct 2017
    • 1784
    Re: MP 501 Paper tray 2 dont lift paper
    Originally posted by Codex
    Hello guys
    Thank You !
    "if you move it, it starts to lift", this is how the lifting motor needs to be replaced, however if you suspect it is a size issue, you can try disabling it with sp-5148-001 (size detection on/off)
    "I'll be back"
    • Codex
      • May 2008
      • 704
      If i push the tray the Motor starts to lift... Even if the tray is open and i push the paper size selector on the right side
      Inviato dal mio SM-S901B utilizzando Tapatalk
      • luca72
        • Oct 2017
        • 1784
        its normal that you push with the finger the switch, the lifter motor run, check if rear plastic of tray 2 are deformed, and dont push well any switch...and disable for a test the sp detection size
        "I'll be back"
          • 37532
          I've had the size selector switch go flaky.
