Ricoh 4504 ex SC-995-01 After replacing board
  • Jinn
    • May 2023
    • 120
    After replacing the main board of a working machine in another same model machine it is throwing error code. SC-995-01. I have checked 5811 SP mode. Serial # are same in BC & Display. FRAM is not showing.
    any suggestions?
    Many Thanks
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh 4504 ex SC-995-01 After replacing board
    Are the engine numbers on the serial number stickers the same?
    Hit it.
    • RicohBoomer
      • May 2022
      • 40
      Did you log into factory SP or regular SP?
      I'm fairly certain that the one that is mismatching is the one contained in factory.
      Log into factory and check 5811 again for any mismatch.
      • Jinn
        • May 2023
        • 120
        In Sp mode 5811, Display Serial # and BCU Serial # are same as printed on Serial Number sticker at the rear end of machine.
        I didnt change the ICs NV-RAMs on the control board and one on the BCU.
        Error SC-995-01
        • emiliorsg
          • Jul 2018
          • 141
          You need to put the nvram of the old pcb into the new one and set the serial no to sp5-811-004 and reboot
            • 37444
            +1
            • Jinn
              • May 2023
              • 120
              There are two NVRAMs M1 & M2. I have to replace both? and If after checking I will install the rams back to original board it will work after that ?
              • emiliorsg
                • Jul 2018
                • 141
                Whenever a pcb is changed, the nvram from the previous board is installed, as many as it has. I don't recommend that you play with NVRAM because they are easy to break, especially if you are not used to it.
                  • 37444
                  And according to the service manual, you will still have to do sp5-811-004 and reboot.
                  • Popolopo
                    • May 2023
                    • 126
                    Have to change serial number according novita. Can find it at factory sp mode.
                    The easiest solution, just use the old nv-ram, put back both 1 and 2, at the right spot. Then , no need to change serial number.
