Ricoh mpc4503 SC490-00 at start up
  • Pixtech Frameworks
    • May 2020
    • 238
    Good Days,
    Hope this post finds everyone well. Having sc490-00 at machine start up. Changed all PCDU and all peripherals still no luck
  • DeepRepair
    • Nov 2023
    • 22
    Re: Ricoh mpc4503 SC490-00 at start up
    That code is not listed in mpc4503 will not be sc491?
      • 37489
      Are you sure it is a SC490 and not 491 or 492? I do not see SC490 listed in the service manual for the 03s. I do see it in Goose's Guide for older models as being either a fan problem or a MUSIC error.
        • May 2020
        • 238
        I beg your pardon. It's for sc491-00. Thanks Slimslob for drawing my attention.
        • copier tech
          • 8144
          • Code: SC491-00
          • Description:High voltage power source: charge/development: output error SC detection signal (charge/development) is L (abnormal) for 200 ms consecutively during high voltage (charge/development) output.
          • Causes:Remedy:
            • May 2020
            • 238
            • Code: SC491-00
            • Causes:Remedy:
            Suspecting high voltage power supply board or blown out fuse, because the said machine was working perfectly before I was told by the customer that sudden sc491-00 showed up.
            • copier tech
              • 8144
              A firmware update usually resolves this issue.
                • May 2020
                • 238
                How do I update or know if firmware is outdated.
                • copier tech
                  • 8144
                  We can supply you with the latest firmware complete with instructions.
                  Please contact us via either web site below.
                    • May 2020
                    • 238
                    I have found the solution guys, it happens to be High voltage board AZ320204 (3E079310A) was the curpit. I guess it was low voltage that damaged it, unlike 04/Ex series that complains when it detects a low voltage.
                    Thanks for the various contributions and assistance.
                    Attached is the picture or the board
