ricoh webimage
  • aviso66
    • Dec 2012
    • 202
    ricoh webimage
    Does anyone encounterr this when you access ricoh webimage it says:
    Connection not secured?
  • Saturn
    • Nov 2023
    • 172
    Re: ricoh webimage
    As far as I know, the message is shown when an old machine does not support https. You can proceed anyway.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • Tony in Oz
      • Dec 2021
      • 13
      Re: ricoh webimage
      i get similar messages when Airprint is enabled, you can usually proceed to the page thou
      • copier tech
        • 8220
        Re: ricoh webimage
        Depending on which model ? if you update the firmware this can resolve many WIM connection / security errors.
          • 37627
          Re: ricoh webimage
          Depending on the browser you're using it might be an expired certificate.
          • rthonpm
            • Aug 2007
            • 2860
            Re: ricoh webimage
            Or more likely no certificate at all. Most browsers have been giving an alert for any website not using HTTPS for at least the last two or three years.
            Sent from my Pixel 6 Pro using Tapatalk
