6002 Jam codes
  • mikadonovan
    • May 2008
    • 2931
    6002 Jam codes
    Hi, All. I have a MP6002 with a SR 4080 finisher attached. I am getting misfeeds with a jam code of 151. Only problem is, there is no jam code 151 listed in the tables. I believe that it has something to do with the punch unit (maybe) due to where I am finding paper at. However, I can run 100 punched sheets with no misfeeds sometimes. Driving me nuts. Any assistance will be appreciated.
    NEVER ASSUME ANYTHING
  • Codex
    • May 2008
    • 704
    Re: 6002 Jam codes
    Hello
    If you check the Mp6001 series... J151 is "Entrance sensor".... But in the B830 finisher, ricoh jam codes are all similar... Maybe this helps
    Inviato dal mio SM-S901B utilizzando Tapatalk
    Memento Audere Semper
      • 37489
      Re: 6002 Jam codes
      Originally posted by Codex
      Hello
      Looking at SP7-504 Paper Jam Location, 151 is finisher entrance for any finisher.
      • mikadonovan
        • May 2008
        • 2931
        Re: 6002 Jam codes
        I figured it out. The bottom of the finisher entrance guide is supposed a locator pin to restrict side to side movement. This one does not.
