SPC252 - error memory overflow and not print
  • aguatepe
    • Jul 2015
    • 28
    Hello everyone and happy holidays.
    I bought a SPC252 for home.
    Upon installing it I find that when I try to print I get message "memory overflow".
    From the iOS mobile app (Connector) I cannot print , I always get this message.
    From the pc, sometimes I get this message and sometimes not.
    I have tried
    - Reset factory settings.
    - Deleting all fax files.
    Through WIM I can't change settings, the password doesn't work (Admin, Admin074, password, blank).
    Memory 256MB
    Firm Version: 1.17
    Engine Version: 1.01
    Network version 0.47.
    Can anyone give me an idea if there is any new firmware that specifically fixes this, or any settings I can apply ?
    Many thanks
    • 37252
    Re: SPC252 - error memory overflow and not print
    Which driver are you using and what port? If you allowed Windows to automatically detect and install it, they are probably both wrong.
    • aguatepe
      • Jul 2015
      • 28
      hi !
      In the first instance I used the old spc232 driver already instsalled in pc, and I don't remember this problem, but I only tested a few pages.
      Then I installed the universal pcl6 of the spc252 directly by tcp/ip not automatically.
        • 37252
        Driver for Universal Print could be your problem. Use the PCL 6 Driver Ver.1.00
        • aguatepe
          • Jul 2015
          • 28
          i will try to install a new driver and test it.
          in other hand from my mobile iOS i havent able to print, i always get a error memory sms.
            • 8131
            I have tried
            Memory 256MB
            Firm Version: 1.17
            Many thanks
            Was this a new device ? does it let you copy / scan ? if not the previous owner may have locked prints stored, try deleting them all.
            Or access service mode & perform an all clear & update the firmware.
            Can you log in the WIM as supervisor to change the admin password ?
            โ€‹
            • aguatepe
              • Jul 2015
              • 28
              Hello!
              It is not new.
              I think it is not that the printing is blocked, because I have been able to print pages from office without any problem.
              I have already got the firmware.
              I have not tried login with supervisor (I have to test it).
              I have the printer installed at a cousin house, when I have to go there I will do all the tests.
              many thanks
