A yellow band on solid occurs on cross feed(PRO c5200&5300)
  • Marwan
    • Oct 2023
    • 31
    greetings all.
    I have a Pro c5200s&5300s have same issue with yellow bands happens on cross feed,i have changed opc,developer and charge unit still same issue,
    any suggestion please?
    PS: i have attached the issue but it pearly appeared on the bottom and it occurs on whole page but strong as it seems,looks like a rotate of the opc
    thanks in advancewilliam.pdf
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: A yellow band on solid occurs on cross feed(PRO c5200&5300)
    What sort of mileage do the dev units themselves have on them?
    Hit it.
    • bat
      • Sep 2008
      • 140
      This is a development unit issue, run full dot pattern to identify unit.
      • Oze
        Ricoh Fanboy
        • 1663
        99.9% certain that there are numerous bulletins from Ricoh about this issue.
          • 37584
          Originally posted by Marwan
          greetings all.
          thanks in advance[ATTACH]60961[/ATTACH]
          Did you rebuild the drum cleaning station when you replaced the OPC drum?
          • Marwan
            • Oct 2023
            • 31
            sorry for the late replay,
            after many jamz and replace many spare parts the tick came up with the machine was unhelpful so i tried to clean the lazer glass manually and the problem solved,but i'm not convinced how that would lead to that issue,,
            thankss for all
