Ricoh MPC4504
  • aviso66
    • Dec 2012
    • 202
    Ricoh MPC4504
    Hi, I have a strange occcurance of my ricoh MPC4504, if i connect the copier using WIFI connections, i am not able to access the web image from the IP. why is that? the machine model is ricoh mpc4504 colour
  • copier tech
    • 8236
    Re: Ricoh MPC4504
    Are you connecting via the SOP wifi or do you have the optional wifi card / kit installed ?
    The SOP wifi will not allow you to access the device WIM.
    • Codex
      • May 2008
      • 705
      Re: Ricoh MPC4504
      Hello
      If the machine has a SOP you have to add the port after the IP Adress on your browser, ex: 192.168.1.20:53080
      you can check the forwarding options in the menu "PORT FORVARDING" you have to turn it on, an there you can see a table with the assigned ports for various services (this because if you connect with WIFI the SOP have to forward the comands to the machine using the port forwarding option)
      Memento Audere Semper
      • aviso66
        • Dec 2012
        • 202
        Re: Ricoh MPC4504
        Hi,
        I am not sure what is SOP wifi, but it works like this
        How To Connect Your Ricoh Printer To A Wi-fi Network, Ricoh How to connect with wi-fi,ricoh printer. - YouTube
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Re: Ricoh MPC4504
          Right.....so essentially the ONLY thing you've managed to connect to your WIFI network is the operating panel (SOP)...not the actual machine.
          To be able to print, scan and access the Web Interface of the machine you need to connect the actual machine itself to your WIFI network and the panel alone cannot do this.
          You need a WIFI Range extender.
          And...are you REALLY a tech?
          You can tell us...
            • 37641
            Re: Ricoh MPC4504
            If you do not have a wired network jack near the C4504, you need to get a WiFi Range Extender with a LAN port and a patch cord to connect it to the C4504.
            • aviso66
              • Dec 2012
              • 202
              Re: Ricoh MPC4504
              You can tell us...
              owh thanks for the info. yup it was able to print
