i need help i have error in richo 7100 code sc-381-02
  • aymanfarhan
    • Jan 2024
    • 7
    how fix this error
    thank you 4 all
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: i need help i have error in richo 7100 code sc-381-02
    Pretty sure that's a Cyan Potential sensor issue.
    I'm fighting an SC381-04 error.
    If the machine is still on original drums I would certainly change the drum and clean or replace the Cyan potential sensor.
    • aymanfarhan
      • Jan 2024
      • 7
      where the sensor
      • dalewb74
        • Feb 2018
        • 1125
        where is your service manual? it would tell you what the code means. and it will also tell you where the sensor is located. very wise to have the manual. if you don't know what you are doing you can brick a machine.
        • bat
          • Sep 2008
          • 140
          The Ricoh Pro C7100 is a production printer, call a trained technitian.
          • aymanfarhan
            • Jan 2024
            • 7
            Originally posted by dalewb74
            where is your service manual? It would tell you what the code means. And it will also tell you where the sensor is located. Very wise to have the manual. If you don't know what you are doing you can brick a machine.
            i have not you can give me the manual
            i want see the seinsor
            • dalewb74
              • Feb 2018
              • 1125
              please take a moment and read batmans post.....
