Ricoh toner flaking
  • EchteTechnieker
    • Jan 2024
    • 1
    Ricoh toner flaking
    Hello, I have the following problem with Ricoh 3003 - 6003: sometimes it seems as if the ink is flaking off, then you see a stamp on the next page. We usually solve this by raising the temperature of the fuser, but this does not always work. we sometimes use original toners, but not always. could it have something to do with this?
  • DeepRepair
    • Nov 2023
    • 22
    Re: Ricoh toner flaking
    Possible causes
    Poor quality toner
    Fuser problems
    Development unit problems
    Overtime Developer
    Misconfigured paper
    • luca72
      • Oct 2017
      • 1791
      cleaning thermistors or replacing them, increase the paper weight setting (even by quite a bit), and/or set the driver setting to "quality"
      "I'll be back"
      • mrwho
        Major Asshole!
        • 4299
        And yes: non-original toner could cause that (not that it's forcibly your problem, but don't discard the possibility yet).
        Mascan42
        Ibid
          • 37556
          Once you have used non Ricoh toner, the developer is contaminated.
          • Oze
            Ricoh Fanboy
            • 1663
            A qualified Ricoh trained tech can sort that for you.
            Contact your nearest dealer.
            • mrwho
              Major Asshole!
              • 4299
              A possible solution for that is to replace the aftermarket toner with an OEM one and then take about 40 A3/DLT skyshots to force the complete refresh of the toner in the developer. I've done it before.
              Mascan42
              Ibid
