Scan tok mail
  • pakobernal
    • May 2012
    • 46
    Scan tok mail
    Greetings from Spain, can someone explain to me how to configure scanning to email on a Ricoh MP 201?
  • copier tech
    • 8220
    Re: Scan tok mail
    There is loads of info on this topic. Try a quick good search.
    Ricoh Customer Support - How to configure Scan to Email - YouTube
    • pakobernal
      • May 2012
      • 46
      Re: Scan tok mail
      Thanks, but I know the steps, but mp201 doesn't configure ssl and the most of accounts of mails has ssl.
      Mail without.ssl????
      • davidmtupper
        • Jul 2021
        • 326
        Re: Scan tok mail
        You need either a different email service, there are a few that don't require ssl, or a newer MFP that supports it.
          • 37628
          Re: Scan tok mail
          Stunnel
          • pakobernal
            • May 2012
            • 46
            Re: Scan tok mail
            Stunnel
            Any manual on how to use it?
              • 37628
              Re: Scan tok mail
              Program and documentation are available inline.
              • rthonpm
                • Aug 2007
                • 2860
                Re: Scan tok mail
                Like here:
                stunnel: Examples
                Sent from my Pixel 6 Pro using Tapatalk
                • pakobernal
                  • May 2012
                  • 46
                  Re: Scan tok mail
                  Originally posted by rthonpm
                  Like here:
                  stunnel: Examples
                  But, I have a question, isn't there a domain like Gmail, where you can create an email account that does not have SSL security? In short, I need an xxx@yyy.com email account that does not have ssl to be able to configure scan to email on a Ricoh series 0 or series 1 machine.
                  Does anyone know any?
                    • 37628
                    Re: Scan tok mail
                    That was discontinued for most users during the pandemic. If you are using a "free" gmail account, forget it. If you are using a corporate, paid for, Google Workspace, account there are a couple of ways. Each has restrictions.
                    This article is for Google Workspace administrators who want to send email from devices or apps in their organization or domain. If you're a Gmail user who wants to send email from a device or app, contact your organization's administrator. Send email from a printer, scanner, or app - Google Workspace Admin Help
                    The first option is using a relay server. It can be either Google's relay service, which your organizational administer has to add to the corporate account and configure. Or you can use a third party relay which Stunnel is an example.
                    Also check with your internet service provider. Some also provide email relay service. Like Google, they provide it but you have to configure and manage it.
                    • pakobernal
                      • May 2012
                      • 46
                      Re: Scan tok mail
                      And another mail server other than Gmail, that is free and does not have SSL?
                      • rthonpm
                        • Aug 2007
                        • 2860
                        Re: Scan tok mail
                        Slim answered that already. You're not going to find a reliable email provider that doesn't require TLS, nor would you want to use one.
                        • pakobernal
                          • May 2012
                          • 46
                          Re: Scan tok mail
                          The problem is that mp201 gives the following message in the ssl/tls security option:
                          SSL/TLS is not available without device certificate installation.
                          Can this problem be solved in any way?
                          • rthonpm
                            • Aug 2007
                            • 2860
                            Re: Scan tok mail
                            That's TLS for the web interface, not SMTP. All of the settings you need should be under Email.
                              • 37628
                              Re: Scan tok mail
                              You can export a certificate from your browser and then import to your MP 201 using WIM. Here is a Knowledge base article from 2011 that explains the procedure. Of course the browsers have changed but adding a Site Certificate to using WIM is still the same How do I setup SMTP over SSL on a Ricoh Family group device.pdf
