Dotted copy on ricoh aficio 1045
  • Edutech
    • 16
    The copy had vertical lines as a result of the charger roller getting dirty. I did replace the drum cleaning blade but had to clean the charger roller before installing the unit back to the machine. After cleaning the charger roller with a dump piece of cloth, I dried it and then assembled the unit appropriately. After making a copy, the 1st one was perfect but the other copies had black irregular dots all over the print copy. What can i do to avoid this occurence?
    "Everything is okay in the end, if it's not ok, then it's not the end."
  • Captain Scott
    • Dec 2008
    • 166
    Vac out recyling
    Strip the drum unit, vac out recycling section, make sure seals are not bent, powder drum with toner. Its always better to replace all drum unit parts as a set..clean charge and cleaner and brass bushings and ..be carefull what you say its a very sensitive area
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      yeah replace as set thn be carefull in putting in back like plastic bushing and spring.. etc...
      fix the customer first then fix the machine... its simple and makes life more easy.
      • kyoceran
        • 100
        you may need to replace the cleaning unit seal, also check for spray from the ends of the cleaner box rotating scraper.
        • ccchuah
          • Mar 2009
          • 155
          The charge roller line was caused by the sparking tiny holes on the drum, avoid using damp cloth to clean the drum, it will sparking to the drum,you will notice tiny marks on the drum, and cause you more dots on the copy. Only solution is to replace the drum.
          • Edutech
            • 16
            Dotted copy on 1045
            Thanks guys for your contribution. I am now more informed than I was. I will post the results after replacing another one as a set. Again i am thankful to you all.
            • tcs04
              FORMER Techie
              • 1183
              Just a thought.
              I recall that the complete PCU for the AF1045 was actually cheaper than the cost of the drum and cleaning blade (!) In the UK.
              It must be worth checking the cost and changing the whole unit if cheaper?
              • Bradomin
                The charge roller cause tiny marks on the drum, the solution is to replace the drum and the charge roller.
                • rthonpm
                  • Aug 2007
                  • 2852
                  The charge rollers on the 5635 always got dirty far too early in the PM cycle. After replacing the drum, charge and blade, also replace the charge roller cleaning brush with the updated G7902329 brush for the MP 3500 series machines. The surface of this brush does a much better job of cleaning the charge roller and allows you to get more life out of it.
