MP3554 remove paper from shift tray
  • apump
    • Mar 2009
    • 160
    legal and 11x17 from glass or document feeder it shows remove paper from finisher shift tray after copies exit. Letter and letterR are fine. When it does this you have to reboot machine to clear message. anyone seen this before?
  • ridgemill
    • Sep 2017
    • 190
    Re: MP3554 remove paper from shift tray
    Make sure the finisher firmware is up to date. Both SR3140/SR3150 & SR3160/SR3170, have updates that fix false full tray conditions.
      • 37524
      I have had the problem with the Proof tray. It was caused by ambient light from lighting on low ceiling above the finisher being reflected off the surface of the first sheet exiting to the full tray sensor. Solution was to place my clipboard or a couple sheets over the proof tray before starting to print reports.
