MP3055
  • tcypy1961
    • 773
    [Misc] MP3055
  • blee
    Technical Trainer
    • 54
    Re: MP3055
    Sounds like the wrong print driver or possibly the print driver set up as a windows WSD port. They need to make sure it is a TCP/IP port and not WSD.
      • 37494
      Re: MP3055
      Some setting in the document concerning the paper does not match the settings at the MP 3055. There is a setting in User Tools to tell the 3055 to use the job (computer/command) settings instead of the machine settings.
      • kleankopy
        • Feb 2016
        • 114
        Re: MP3055
        Download the correct driver and use ip address and problem will be solved.
        • luca72
          • Oct 2017
          • 1780
          Re: MP3055
          use pcl 6 driver, and try to verify that in user tools>printers settings, stay on "auto-continue=immediate"
          "I'll be back"
          • Lord F
            • Oct 2023
            • 6
            Re: MP3055
            Hi, tcypy1961. Go to User Tools -> Printer Settings and check whether Auto Continue is switched on (Set it to Immediate). I have had this resolve this very issue. But, as others have said - PCL6 and TCP/IP and NOT WSD.
            • Lord F
              • Oct 2023
              • 6
              Re: MP3055
              Sorry, Luca72 , hadn't seen your post when I added mine!
              • mrwho
                Major Asshole!
                • 4299
                Re: MP3055
                Does it happen on *every* print job?
                If not, some aplications (MS Office, Acrobat Reader) might ignore the driver settings and send their own paper formats.
                Mascan42
                Ibid
                • luca72
                  • Oct 2017
                  • 1780
                  Re: MP3055
                  I believe you can give the same answer as others, they don't necessarily all have to answer differently, especially since that tends to be the solution... I receive at least one/two phone calls a week for that problem
                  "I'll be back"
