Ricoh c2004ex issues with scan to media
  • Moen
    • Jan 2024
    • 4
    Hi, i am trying to setup a printer that was donated to a wind band.
    Previous it was locked to a corporate network down and only used with safeQ
    I have disabled all user authentications and uninstalled safeQ, and so far i can print via usb cable and copy freely. But when it comes to scanning i get the message "You do not have the privileges to use this function."
    It will not be connected to any network so what i am trying to get working is scanning to usb media. It allows browsing the usb stick to print.
    I have done firmware upgrade.
    I have also tried to scan while logged in as admin that gave the same message
    I am thinking of trying to set up an account m, like this the next time i am at it.
    An access privilege error appears while printing or starting up an application - Ricoh
    Any hints
  • Saturn
    • Nov 2023
    • 171
    Re: Ricoh c2004ex issues with scan to media
    I would suggest to delete all user settings. To do this, you must first activate the Device Administrator and give him all privileges.
    Then go to page 3/5 in the Administrator Tools and execute "Erase all Memory". This will reset all user settings to factory default.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • 37524
      Also in Administrator Tools disable all user authentication.
      • Moen
        • Jan 2024
        • 4
        Thanks i will try this.
          • 37524
          One other thing, make sure you are NOT logged in as an Admin when you try to use a function. Admins are nor authorized to use functions. Exiting User Tools does not automatically log you off.
          • Moen
            • Jan 2024
            • 4
            Oh thanks that is usefull information, I will have some time to tinker with this next week.
            However i am starting to wonder/realise that i had to have "user code" enabled to be able to print...
            Why do this printer have to be so advanced, with so many options.
              • 37524
              User codes are needed only if you wish to track use by each individual or the machine is located where unauthorized people might have access to it.
              • Moen
                • Jan 2024
                • 4
                Thanks it seem'd so unintuitive that it had to be enabled, so now it is not.
                Now i have erased all data. Now everyone can do everything
                Thanks.
