Ricoh Pro C9200 Printer. SC530-47, SC530-48, SC530-49, Fan Error codes???
  • PDX_KILLA
    • Jan 2024
    • 9
    [Error Code] Ricoh Pro C9200 Printer. SC530-47, SC530-48, SC530-49, Fan Error codes???
    Ricoh Pro C9200 Printer. SC530-47, SC530-48, SC530-49, Fuser Fan Error codes???
    Already replaced 3 fans under fuser web and reset SC codes.
    Still getting same codes? Something I'm missing?
    • 37642
    Re: Ricoh Pro C9200 Printer. SC530-47, SC530-48, SC530-49, Fan Error codes???
    Check the filters associated with the fans. If they are in need of replacement, they will overload the fan.
    • anothertech
      • 1771
      Maybe paper stuck in the drawer connector? Does the code reset and then comes back after a while, or does it never reset?
      • anothertech
        • 1771
        Harness.pdf
        Check out this bulletin that just came out. I don't know if it powers the fans or not, might be worth looking into.
        • PDX_KILLA
          • Jan 2024
          • 9
          I ordered new fans and the new harnesses. Will definitely let you guys know what the outcome is. TY for the fast reply.
          • PDX_KILLA
            • Jan 2024
            • 9
            So received new fans today. No harnesses, but tried replacing the fans still same code.
            What are the chances its actually the wiring harness?
            • Vin
              • Aug 2023
              • 5
              Had a similar issue on a pro c7100, there was a connector for an extra fan which someone connected to a connector going to a sensor, they fit perfectly and one would easily make that mistake, so I replaced the smd fuse on the I/O board and disconnected the connector going to the sensor and that fixed the issue.
              • anothertech
                • 1771
                Do you have a case open with Ricoh Xpress support?
                • PDX_KILLA
                  • Jan 2024
                  • 9
                  My boss has an ongoing dispute, with POA right now. I have been trying to keep the machine running for the last year on my own. Can I still reach out to them?
                    • 37642
                    Doesn't hurt to try.
                    • PDX_KILLA
                      • Jan 2024
                      • 9
                      They tell me to pay the bill or no help.
                      Its the Ricoh Legal Organized Crime Syndicate!
                      • anothertech
                        • 1771
                        It's the same with any company. If you don't pay your bill, they're not going to continue to provide service.
                          • 37642
                          If your boss isn't paying his bill from Ricoh, I wonder how soon your paycheck is going to bounce?
                          • PDX_KILLA
                            • Jan 2024
                            • 9
                            Months ago. Come on now.
                              • 37642
                              And when the customer complains to your boss about the C9200 not getting fixed in a timely fashion, whom do you think your boss is going to blame, himself for not paying Ricoh or you?
