ricoh 2035e sc 329
  • vale24
    • Sep 2008
    • 62
    ricoh 2035e sc 329
    Hi, what is SC 329 error code on Ricoh 2035e?
    copier and printer service technician
    The perfect gift
  • Jomama46
    • 2900
    SC329: Laser beam pitch adjustment error (B)
    The LD unit HP sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the dpi.
    sigpic
    A+; Network +; PDI+
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      SC 329 level B
      symtom LD unit beam pitch adjusted incorrectly
      the ON condition while changing the LD
      Possible Cause
      After initialization of the SP modes,
      SP2-109-3 or SP2-109-4 was not
      executed.
      The harness is blocking the LD drive
      (PCB), preventing adjustment of the
      pitch.
      fix the customer first then fix the machine... its simple and makes life more easy.
      • ccchuah
        • Mar 2009
        • 153
        If the toner is dropping a lot on the LD board, then the board must be soldering out the laser diode, and clean the inside unit of the assembly. Clean all mirror inside the laser unit, perform the laser beam pitch adjustment.
        • etsmultan
          • Apr 2007
          • 131
          Go to sp mode then apply code 21093 nd execute 400dpi,600dpi nd then on/off
          • vale24
            • Sep 2008
            • 62
            thanks
            I did this SP 21093 and 4 and now working....
            Thanks !
            The perfect gift
