sc530-14 on 8200
  • thecopycenter
    • Oct 2016
    • 9
    sc530-14 on 8200
    checked the fan motors, all spin.. Heat pipe fans spin... switched fans with known working 8200 cant clear the code...any help would be appreciated
    reset scjam, sc reset, still codes out just before coming to ready...
    t
  • Saturn
    • Nov 2023
    • 171
    Re: sc530-14 on 8200
    SP 8200dn or Pro 8200?
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • thecopycenter
      • Oct 2016
      • 9
      Pro 8200
      • anothertech
        • 1771
        I can't find any hits on it in goose guide or the knowledge base. I guess you're going to have to break out the point to point and check the signal coming from the board. If good signal from the board, maybe harness problem?
        • mfrigault
          • Feb 2017
          • 18
          The Fusing Air Intake lower left and lower right fans have the same p/n. Just switch them over to see if the error code follows.
          • thecopycenter
            • Oct 2016
            • 9
            When you are looking from the back of the machine, where would they be located?// We changed out the toner outlet sub unit, made sure all fans were connected, then the 530-14 code came up.
            We changed the whole unit that holds the fuser and reg units, changed the board that has the heat pipe fan unit, and changed the wiring.. still cant get rid of the code.. did a 5810 reset, still the same...
            t
            • mfrigault
              • Feb 2017
              • 18
              The air intake fans are located on the fixing heat shield unit, above the fixing unit - the fans are accessible from the back of the device.
              Remove the exhaust cover and rear right cover. The fans are located on top side-by-side, the one giving the SC code is the one on the right.
                • 37556
                [ATTACH=CONFIG]61441[/ATTACH]
                If there is a filter(s) it(they) will be located in the exhaust cover
                • thecopycenter
                  • Oct 2016
                  • 9
                  [QUOTE=mfrigault;2581081]The air intake fans are located on the fixing heat shield unit, above the fixing unit - the fans are accessible from the back of the device.
                  Pro8200.jpgI will try and replace that one.. I replaced the ones just below that set of 4..will let you know...Thanks
                  • anothertech
                    • 1771
                    8200 fans.pdf
                    On this diagram, I believe the two fans to switch are number 17 and 18.
                    Or it might be number 14.
                    Hint: It's probably one of the fans you disconnected to replace the toner outlet sub unit.
                    • mfrigault
                      • Feb 2017
                      • 18
                      SC530-14 is "Fusing air intake fan: lower left" -- This fan is #3 on the diagram.
                      • thecopycenter
                        • Oct 2016
                        • 9
                        got it working, Thank you for your help.. Do you have anything on the steps of replacing the Drag motor... I took the finisher apart but need a step by step process for replacing the drag motor on the 8200 finisher
                        • mfrigault
                          • Feb 2017
                          • 18
                          Glad I could help !
                          For the Drag Roller Motor, well you will need the service manual for the steps. Attached are some screenshots from SM.
                          Basically, you need to remove the right upper back cover of the finisher, jogger unit cover (2 screws), jogger unit (2 screws and 1 harness)
                          , exit roller cover (2 screws in back, 2 in front) and drag roller unit (2 screws in back, 2 in front and some harnesses).
                          Jogger unit cover.jpgExit roller cover.jpgDrag roller unit..jpgDrag roller unit.jpg
