MP C6502 with an E-22 Fiery,long paper printing
  • anpetros
    • May 2011
    • 43
    [Misc] MP C6502 with an E-22 Fiery,long paper printing
    Hello everyone.I need your valuable help!
    I have an Mp c6502with the e-22 fiery controller and i cannot feed long paper from the b/p tray.
    I have activated the sp concerning allowance for bypass long paper,but the driver setting, for custom paper ,allows only up to 487mm length.
    From the copier panel i can adjust the b/p to feed paper up to 1260 mm and as a copier works like a charm. But not from the driver.Ther is no selection for custom 1260mm long.
    I had an idea of adding pro c5100's driver,which uses the same fiery,and the selection for 330x1260 paper is there.But when i send the print command the copier responds as:Invalid paper size was specified.Press <reset > to cancel job,and no other command is allowed .not form feed.What am i missing here?
  • dalewb74
    • Feb 2018
    • 1153
    Re: MP C6502 with an E-22 Fiery,long paper printing
    your copier has the banner attachment?
      • 37488
      Banner printing is only available for the GW controller not the Fiery. If you want to do banner printing, you will need to disconnect the fiery and enable the GW controller and connect to the connect to the standard network jack and not the Gigabyte port.
      • anpetros
        • May 2011
        • 43
        Sorry ,no i am not familiar with that.Is it an option?
        • anpetros
          • May 2011
          • 43
          Omg,thank you.But why is the driver for pro c5100 gives you the dimensions?
          • Saturn
            • Nov 2023
            • 171
            You don't necessarily need the banner option. If the paper size is set correctly, it also works without the banner option. It just makes handling the paper easier.
            I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
              • 37488
              It most likely has to do with the firmware for the 1 GB interface card that the Fiery has to talk to the C6502 through. If you wanted the Fiery features of the Pro C5100 you should have purchased the Pro C5100 instead of the MP C6502.
