I have a 1224c with a strange problem... go figure! In B/W mode everything works just fine. In color mode, the first 2 copies look good, everything after that smears like the ITB wasn't cleaning properly (new pcu) or the quencing lamps were out (working fine)
The recommended fix is to push it off of a tall building, but we're not able to do that - customer thinks it would be an insult to the sidewalk. He also noted the possibility of a fissure opening up so the blasted thing could drop straight to hell, and doesn't know how to file that on his insurance...
The sample below is an internal test print, checkerboard pattern. As I said, the PCU and developers are new. Fuser is in good shape. Cleaning clutches, bushings, and drive are new/checked & cleaned.
Ideas?
Ideas?
