c2004ex Help wifi and bluetooth
  • Bubbajoe
    • Mar 2024
    • 3
    Hey All.
    Just got this printer second hand with my shop. I for this life of me can not get it to print from my phone or from the internet. It says something like user can not be guest. Help please. it can't be this hard. Thanks its a Ricoh MP C2004ex
  • sandmanmac
    • 3981
    Re: c2004ex Help wifi and bluetooth
    Originally posted by Bubbajoe
    Hey All.
    You won't be printing from anything until it's properly connected to your local network, which you've not bothered to mention whether or not it is
    • dalewb74
      • Feb 2018
      • 1153
      that model has neither bluetooth, nor wi-fi. yes it has something on it that, for whatever reason, ricoh calls it wi-fi. it is not wi-fi. so you need to get it connected to your network.
      • Bubbajoe
        • Mar 2024
        • 3
          • 37488
          Actually the Smart Operation Panel has both plus NFC. They are all very short range and are used to connect to the android OS of the panel and not to the engine.
            • 37488
            Hard wire internet or LAN, Local Area Network?
            • Bubbajoe
              • Mar 2024
              • 3
              hard wired like directly plugged into the router
                • 37488
                Do you know what the IPO address is?
                If you know the IP address, can you ping it from your computer?
                Is the network jack enabled? Check SP 5985-001, it needs to be set to 1.
                • dalewb74
                  • Feb 2018
                  • 1153
                  i agree, but it is such a pain to deal with. and beyond what most people would understand. it's not exactly user friendly. though i haven't messed with it in a good while now.
                  • luca72
                    • Oct 2017
                    • 1778
                    Hey All.
                    you can use one of these, it costs very little, and I saw here on the forum everyone is very enthusiastic, then, for the smartphone, you download the ricoh connector or mopria print app, and you should be able to print.
                    it connects directly to the copier's LAN port with a cable and you can attach it to the back with Velcro
                    TL-WR802N | Client Router (Ethernet | WISP) Wi-Fi N300 | TP-Link Italia
                    "I'll be back"
