Ricoh pro c7200 background on gloss papers
  • gilbert
    • Oct 2017
    • 38
    [Misc] Ricoh pro c7200 background on gloss papers
    Morning techs
    We have a ricoh proc7200 which which is giving background wherever gloss paper is used, it has done about 4000k plus prints.
    Trying to sort out the issue we replaced most of pm parts, Drums OPCs ,ITB, cleaning units, charger units and developers.
    When we try to do fiery Calibration it was NOT successful, even after general cleaning and replacement of recommended parts,
    Anyone with an ideal what could cause the issue?.
  • kevslane
    • Mar 2017
    • 24
    Re: Ricoh pro c7200 background on gloss papers
    Have you used the media identification tool to see which media in the paper catalogue matches the gloss paper you are using?
    Sent from my SM-A526B using Tapatalk
    • dalewb74
      • Feb 2018
      • 1125
      does it do the same thing on regular paper?
      • gilbert
        • Oct 2017
        • 38
        No its not only on gloss paper more than 150gsm
        • gilbert
          • Oct 2017
          • 38
          Yes we did. it s only happening on gloss paper more than 150gsm.
          • kevslane
            • Mar 2017
            • 24
            Check RTTD0A5007.
              • 37352
              Most quality issues with glossy paper have to do with the fusing unit. Make sure that the paper being used clearly states on the package that it is for use in laser printers. Most are intended for use in ink jet printers ONLY. Some can even have their glossy coating melt and damage the fusing unit. Those that don't melt still require very precise fusing temperature settings. 2 or 3 degrees too high or too low can cause offsetting. Depending on the degree of offsetting it may only look like dirty background.
              • dalewb74
                • Feb 2018
                • 1125
                yeah just what slim said.... plus make sure that your paper settings on the PC and on the printer match what you are using.
                • mrwho
                  Major Asshole!
                  • 4299
                  My money's on replacing the photoconductors.
                  Mascan42
                  Ibid
                  • eccelobo
                    • 113
                    I had the same problem and it was the PTR. Good Luck!
                    • Marwan
                      • Oct 2023
                      • 21
                      First go with face up and face down print to determine if the ptR unit is getting fuslty
                      second try to clean and replaace the potential sensor with another colour and see how it goes
                      thierd check the VR of the PCU if it above 150,you should replace it ,i believe there is an upgrade for it,
                      goooooooooooooooood luck
