Hi, All. I seem to be having a lot of weird issues with the bypasses on this model. The problem appears to be with the lift plate. Is there a RTB that covers this?
Mp c307 bypass
Re: Mp c307 bypass
are you still dealing with the by-pass from last time?"loneliness is an invention of the white man, when we are alone we talk to everything around us, we are never alone" (Ojibwa) -
Re: Mp c307 bypass
I know one common issue with these is that the lift doesn't go all the way up causing an immediate paper jam when the paper doesn't get pulled into the machine.
It is near impossible to see the issue in action but what I've done is apply grease(Can be liquid too but grease is recommended) at the edges of the tray, in the gap where the lift tray moves up and down.
A bit hard to describe but I don't have a picture at hand right now.Comment
