Hello everyone, again. I was wondering if anyone else might be having issues with the MP C2550/2050/2030 models? I've a new install that will not auto-detect the paper size in the bypass. You feed through an 8.5x11 in the df, the bypass pulls the paper and feeds it out to the internal finisher. Before the paper feeds to the finisher, though, the machine says it jammed in B and C. The jam code recorded on the SMC is 57--registration sensor. If I set the size to what ever i place in the bypass then the jam does not occur. Is the bypass on this machine not "smart" enough?
MP C2550--Bypass Jamming
Tags: bypass tray, c2550bypass, ect, forgot, internal finisher, jamming, occur, stuck, system settings
See attachedAttached Files -
I noticed that the bypass label on the MPC2500 (similiar machine) shows paper to be fed short edge first. Have you changed the paper orientation with the bypass set for APS?Do what you can, with what you have, where you are. ~Theodore RooseveltComment
Bypass Tray
For MPC 2030
1. Put Paper on Bypass Tray
2. Look on the panel and Bypass will Appear there
3. Press Enter (#) Button
4. Select Paper Size and then Press OK
5. Select Reguler Size and then Press Ok
6. Select paper what do u put on bypass E G; 8 1/2 X 14 (legal)
7. Press Ok
8. Panel will display 81/2X14
9. Ready to copyComment
Thanks for the responses, fellas. The first reply is the issue (length sensor). What I forgot to mention in the post was that I had tried every which way to feed, including selecting the correct paper sizes for any that I placed in the bypass, setting it in System Settings, pretty much the standard stuff. What I didn't do was take the advice of a fellow tech......K.I.S.S., or Keep It Simple, Stupid.. Essentially he told me to take the "blinders" off. Doesn't happen often that a machine defeats me, but something about this one just put a bug in me!VectorLinux---Check it out!Comment
Thanks for the responses, fellas. The first reply is the issue (length sensor). What I forgot to mention in the post was that I had tried every which way to feed, including selecting the correct paper sizes for any that I placed in the bypass, setting it in System Settings, pretty much the standard stuff. What I didn't do was take the advice of a fellow tech......K.I.S.S., or Keep It Simple, Stupid.. Essentially he told me to take the "blinders" off. Doesn't happen often that a machine defeats me, but something about this one just put a bug in me!Comment
To view this you now have to have the WICE training notes
What was the exact problem? Stuck actuator? Sensor moved? Would be nice to know for future reference, if it's happened once it will probably happen again.Comment
The customer had placed a piece of paper on the bypass tray to help them remember what orientation to place letterhead properly. The tape used to hold this paper in place just slightly covered the slot through which the length sensor popped up through. The actuator could come up, just not far enough. Cut the tape out of the path and all is well!VectorLinux---Check it out!Comment
AHA!
Rule #3: What did the customer do?Comment
