IM C300
  • jrob416
    • May 2011
    • 112
    [Electrical] IM C300
    I recently had to remove the circuit board box off of the back of a IM C 300. In the process, I think I totaled one of the ribbon cables for the ADF. The cable comes from the BICU and is routed to a connector PN M0A05928. The ribbon cable comes into the left hand side of this connector. I can't find a part number for said cable. I think the PN might be D0CB5869, but I can't confirm that with other part sources. Please help.
  • dalewb74
    • Feb 2018
    • 1153
    Re: IM C300
    the part # that you gave. in the parts manual it is labeled as a plate: wire-2. i don't believe that is what you are looking for. as it only appears to be a plate/cover?
    • jrob416
      • May 2011
      • 112
      Re: IM C300
      Yeah, I saw that too. But I didn't see anything labeled as ribbon cable. Thanks for the quick reply.
      • kevslane
        • Mar 2017
        • 24
        Re: IM C300
        You need to look on the P to P manual, probably D0C95210.
        Sent from my SM-A526B using Tapatalk
        • Zeldaman
          • Mar 2011
          • 946
          Re: IM C300
          Hi There!
          Agreing 100% with kevslane, the ffc-number is D0C95210. Partsfinder - ptp-diagramm.
          Greetings...
