mpc305,mpc307,mpc407 toners,drum and other parts info needed
  • fshead
    • 2356
    HI
    I have no choice but to move on from selling low meter mpc401 series to the mpc307 and mpc407 series.
    Can anyone share the code book on what a tech can make interchange between them..
    I tried the mpc305 a while back and got burned with a bunch that the toner coils all blew out after a few months but still shelved a few
    to the side. Anything to look out for?
    Any info appreciated as i am going to pick and choose only low meter boxes...
    2nd tray interchangeable?
    thanks in advance
  • copier tech
    • 8101
    Re: mpc305,mpc307,mpc407 toners,drum and other parts info needed
    Originally posted by fshead
    HI
    thanks in advance
    The MP C307 & 407 are basically the same machine, only difference is the speed.
    Not a bad model. PCDU don't always reach life & had a few with the transfer waste backing up.
    As always keep the firmware updated.
    • fshead
      • 2356
      thanks
      IS it the same engine as the mpc305?
      i was led to believe not all parts interchange??
        • 36812
        thanks
        Looking at the parts catalog, some are, some aren't. Example same AC power supply different BICU.
        • copier tech
          • 8101
          thanks
          No, most parts are not interchangeable with the C305.
          • fshead
            • 2356
            thanks
            i am looking more at transfer units,fuser,and drum/dev even if i have to rip it apart to pop in the 07 housing...
            if i need a board i can always buy a high meter parts machine..
            sorta like using mpc3001 parts in the mpc3002 series...
