Scan to Email using office365
  • Marwan
    • Oct 2023
    • 31
    WhatsApp Image 2024-04-22 at 4.40.43 PM.jpgWhatsApp Image 2024-04-22 at 4.40.43 PM (1).jpggreetings for all,
    recently i'm facing an issue with office365 server,when i ping and insert the server name and try for connection test it doesn't go sucessfully ,it kept waiting.
    is there any other method for scan to email?
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Scan to Email using office365
    Have you tried the MX record trick?
    Hit it.
    • rthonpm
      • Aug 2007
      • 2860
      Microsoft always recommends using the hostname instead of IP: smtp.office365.com as it is a load balanced service running over multiple IPs.
      Does the machine you're on support TLS 1.2? App password for sending emails?
      • copier tech
        • 8237
        Originally posted by Marwan
        [ATTACH=CONFIG]62359[/ATTACH][ATTACH=CONFIG]62360[/ATTACH]greetings for all,
        Turn on DHCP, check your gateway is correct then try a connection test on smtp.gmail.com (your DNS will need to be correct too.) then try smtp.office365.com
        Also you have an SC792 error, I guess because you have a finisher removed but left the bridge unit attached ?
        As always you may find a firmware update resolves the issue.
        • Marwan
          • Oct 2023
          • 31
          Yes sir, i have tried the host name and the TLS is on going through IM c3000 & im c2000 ,just having the hardest time figuring it out
          • Marwan
            • Oct 2023
            • 31
            no sir, i have not heard of that, can you give me a clue plz?
              • 37653
              You need to talk to Microsoft Support as it is a setting o your account with them.
              This might help How to set up a multifunction device or application to send emails using Microsoft 365 or Office 365 | Microsoft Learn
              • TonerMunkeh
                Professional Moron
                • 3865
                Go to MX Lookup Tool - Check your DNS MX Records online - MxToolbox and put the customer's domain in there, it will give you an SMTP server to try something like tonermunkeh-co-uk.mail.protection.outlook.com - use that on port 25 with no authentication.
                Hit it.
