How To Replace The BICU Of IMC3000?
  • God of Mint
    • Aug 2023
    • 2
    [Electrical] How To Replace The BICU Of IMC3000?
    Can somebody teach me how to replace the BICU of the IMC3000? Is this straight forward or do I need to call Ricoh tech support for some codes to be keyed into the machine?
  • Brianneoe
    • May 2015
    • 318
    Re: How To Replace The BICU Of IMC3000?
    • When replacing the BICU, be sure to remove the EEPROM [A] from the old board and install it on the new board. By doing this, the SP and other settings can be carried across.
    • Make sure the serial number is input in the machine for the NVRAM data with SP5-811-004, and then turn the main power off/on, if not, SC995-001 occurs.
      that is it..
    • luca72
      • Oct 2017
      • 1678
      you must follow this procedure.
        • 36856
        Get yourself a copy of the service manual.
        • God of Mint
          • Aug 2023
          • 2
          Thanks everyone. Very supportive community. I was able to replace the BICU properly because of you.
