i did reset total counter af1045, but SC 350 comes frequently
  • JustManuals
    • Jan 2006
    • 9838
    #16
    Originally posted by AV8R
    When you try to screw someone else, sometimes you screw yourself... Good job.
    And along with that.........
    What goes around comes around.
    • Ozzy
      Prince of Darkness
      • Jul 2006
      • 33
      #17
      HaHa
      • 10871087
        • Jan 2005
        • 1062
        #18
        Karma is a bitch
        • ADRIANL
          #19
          bwana
          [do the id sensor initialisation
          =kopiket;74912]dear guys,
          i did reset total counter af 1045 by shorting the nvram, but sc 350 comes frequently and charge voltage becomes 2000v.
          any ideas beside replace the nvram?
          thanks folks[/QUOTE]
          • ADRIANL
            #20
            HI YOU SHOULD PUT ALL THE PARAMETERS FROM THE FACTORY DATA SHEET(INSIDE THE FRONT COVER )BACK AS BEST YOU CAN,AND YOUR SC350 IS THAT YOUR ID SENSOR IS OUT OF SPEC AND NEEDS TO BE RE-INITIALISED I PERSONALLY DONT THINK YOU HAVE COOKED THE NV RAM , IT WOULD'NT WORK AT ALL AND M/C WILL NOT BOOT UP IF THIS WAS THE CASE.THE M/C IS IN A MEMORY CLEARED CONDITION WAITING FOR THIS INFO TO BE RE-ENTERED INTO THE NV RAM SO THE SAME PROCEDURES ARE REQUIRED. I KNOW OF A COMPANY WHO CLEARS THE NV RAM ON THEIR REFURB M/Cs ALL THE TIME OBLIVIOUS TO THEIR CLIENTS OF COURSE THEY SEEM TO GET AWAY WITH IT, SO TRY THAT REGARDS ADRIAN .
