Ok folks, here's my saga.
I have a very cheap customer who does his own service, mostly. I came in to the rescue because he put his adf belt bracket on upside down after he replaced the belt, tire and sep tire. I incompleted the call for a T1 feed clutch as it was jamming a bit. He elected to buy the clutch and put it in himself to save on another labor charge, but screwed up the machine somehow while doing it. When I came back, it was doing this:
with cover open, screen is on, displays close cover
with cover closed, screen goes blank, PSU clicks repeatedly
the only way to stop the clicking relay was to turn it on with the IOB unplugged. After reseating most of the connectors, I got the machine to turn on normally with a display on the screen, but now it displays sc901 or sc120. If you do sp 5-810, the wrench light turns off for a half-second and relights again. The mechanical total counter is connected just fine, BTW.
So these folks have paid me two hours of labor so far and I want to be sure the estimate I draw up for them includes everything they might need as I never want to see these bozos again. So far I'm planning to do the IO Board but I wonder if it may need firmware reloaded. Any help is appreciated as I've never seen a copier do the bizarre things this one is doing.
Morgansterne
Morgansterne
